LT Airride on '02 'Burban
Old Nov 21, 2009 | 1:14 AM
jeffs_62's Avatar
Default LT Airride on '02 'Burban
My Suburban has the LT airride system, and it quit working.
I am assuming it's just the pump burned up, but was wondering if therre are other things I should check ou first before just swapping out the pump and find out it's something else.
How does the system actuate?
Please excuse my ignorance. I'm pretty mechanical and I do have a book on this truck. It doesn't say anything in it to help me figure this out.
Old Nov 23, 2009 | 3:36 PM
Strutmastr's Avatar
You have air shocks and a compressor which is controlled by a height sensor in the rear. When the vehicle gets loaded up it kicks on the compressor until it gets to the proper height then shuts off. Once the load is removed, the sensor detects the height again, opening a solenoid valve letting air out to lower it down to level.
What happens with these things is the air shocks will eventually get small leaks causing the compressor to run more often and for longer periods. This eventually overworks the compressor and burns it up. The dealer gets about $400 each for the shocks and $400-500 for the compressor.
The best option is do the conversion kit. It is less expensive. Trouble free and will make the vehicle handle better.
Go to http://www.strutmasters.com/Chevrole...m-suvr1-cs.htm
I happen to work there and deal with air suspension problems for a living. Give me a call and I can tell you all about it.
Angelo
866-597-2397 xt 234
Old Jun 27, 2012 | 5:00 PM
ArnottInc's Avatar
Former Sponsor
Default NEW - Convert your Autoride to Arnott Coil Springs
NEW Arnott / Bilstein 4 Wheel Coil Spring Conversion Kit
Arnott is pleased to announce the introduction of a 4-wheel coil conversion kit for your Suburban, Tahoe & Avalanche. Our complete conversion kit features new specially tuned rear coil springs and four custom designed Bilstein shock absorbers made in the USA! This kit also includes our new device to reliably eliminate any fault codes on your dash panel. This pioneering technology easily connects directly to your vehicles electronics in the matter of minutes.
KIT INCLUDES:
* New Rear Coil Springs
* Front Bilstein Monotube Shocks
* Rear Bilstein Monotube Shocks
* Exclusive Suspension Fault Module
* Detailed Installation Manual
Price - $685.50
Old Nov 19, 2012 | 7:46 PM
rlb55's Avatar
New User
Awaiting E-mail Confirmation
I have a schematic for the air ride suspension on my 2002 Tahoe and have checked ther main fuse of 30 amp and the control fuse of 10 amp and both are good but the ride control relay i can not locate. Can anyone tell me where relay located and the control module for the air ride.
ltayllt
Feb 9, 2017 9:09 AM
osiris
Aug 6, 2007 10:16 PM
southern slammer
Jun 7, 2007 5:43 PM
STiYLIN
Jun 7, 2007 1:06 PM
