Testing GM Navigation Unit
Old Nov 13, 2009 | 5:46 PM
95z115's Avatar
Default Testing GM Navigation Unit
How do I test a GM Denso Navigation unit without having a GM vehicle to install it to? I just want to make sure it turns on and powers up.
I would assume I have to get 12volts to it. Is there some adapter or plug I can plug into the 120v wall outlet with 12v transformer that makes it 12 volts, or can I get a 12volt car /motorcycle battery and wire it directly to that?
Please let me know in detail. I am not even sure which is the power plug on the back of the nav unit!
Thanks in advance for your help...
Old Nov 20, 2009 | 1:58 PM
95z115's Avatar
Does anybody have some friendly advice for me =)
Old Nov 20, 2009 | 3:10 PM
jtstoner's Avatar
Hey I just sent you a private message with some information for testing your unit.
Old Nov 21, 2009 | 9:04 AM
you can't test it on the bench.
You need the vehicle data signal to make the radio turn on. There is no 12v switched supply on 95% of gm's vehicles nowadays
Old Nov 21, 2009 | 11:36 AM
jtstoner's Avatar
Take a look at this auction on eBay. It shows a bench tester for the Nav unit. The item number is 270475965018. Put that number in the search section of ebay.
Old Nov 21, 2009 | 11:37 AM
jtstoner's Avatar
Here is the url http://cgi.ebay.com/07-08-09-gm-TAHO...#ht_500wt_1182
Old Nov 25, 2009 | 12:32 AM
95z115's Avatar
Thanks!
Old Nov 25, 2009 | 8:28 AM
SabrToothSqrl's Avatar
$250 to run one test? unless you could make $ with it...?
Old Nov 26, 2009 | 7:43 PM
my thoughts exactly
biglg
Nov 30, 2006 7:37 PM
biglg
Oct 12, 2006 12:41 AM
kozof
Oct 3, 2006 5:22 PM
