2016 Camaro
Platform: F-Body & Zeta.
Synthetic Vs Non-synthetic
Old Sep 22, 2009 | 9:24 AM
  #11
autotech2's Avatar
It's not mandatory by any means that you change the oil on a new engine at 100 miles. The idea is to remove any metal fragments from the machining process, but the filter will catch them anyway. If you want to do it, go right ahead. It won't hurt anything.
As far as synthetic oil is concerned, the advantage is that synthetic oil (as opposed to petroleum based) holds its viscosity better under extreme high and low temperatures. So if you're at the North Pole, or Death Valley, it certainly can help. Under normal conditions it may not be worth the added expense. However, if it's your love-child Camaro, go for it! No proof, but in my experience there may be a disadvantage to switching back and forth from synthetic to petroleum. So pick one and stick with it.
Old Sep 22, 2009 | 9:50 AM
  #12
you got my attention on this one....please explain the disadvantages of going from one oil to another...
Old Sep 22, 2009 | 10:47 AM
  #13
nauticstar87's Avatar
I've heard that switchign back and forth causes oil leaks because using synthetic conditions and expands seals, and conventional doesn't. or vice versa.
Old Sep 22, 2009 | 11:03 AM
  #14
Mike Sigmond's Avatar
ROTM Coordinator
I have herd the 2 can clump together and cause sludge. I even use full syn in my lawnmower.
Old Sep 22, 2009 | 11:47 AM
  #15
yah i run full syn in my 2500 and love it....i was just wondering because when i bought the truck new it had the wonderful quaker in her....now nothing but amsoil goes in every hole
art
Sep 30, 2020 7:53 AM
Danistheman1234
25
Aug 9, 2011 5:16 PM
Danistheman1234
May 26, 2011 6:59 PM
Rod Man
Nov 6, 2010 9:21 PM
hoytheld
Jan 31, 2007 1:15 PM
